P85D 2015. August 20 ? Firmware update scheduled. Temp controlled Garaged Ambient temperature in 70’s. Next morning dash message “ cell low voltage undriveabke call service. “ but charge “49%” then everything black. No app connection either. For several months I have been complaining about low range and told driving style. Frankly it has not changed. I am not a hot Rodder. I am early on drove to and better than spec. Now 2 mi for every 1% of.capacity.
Service report today: “isolation fault” “ “battery coolant heater”
Is not an isolation fault a short?
Is not the heater supposed to be on only when below 70’s.?
Is not the heater on the high voltage circuit?
Does not a short potentially damage the power source? Ie. Battery.
Does not heat fry the battery?
If heater on when in the 70s and 80s is not heat damaging the battery?
I have been getting low range and have been complaining about it. And I have had excess water draining ( from running cooler- can hear the fan making lots of noise so other people note car is noisier) for months but worse in past month.
Told car not ready as they are waiting for “engineer “ to be checking everything a ok. Is that not HQ engineer? Are they trying to determine damage to battery?
Oh my app now connects. They are charging in the station at 2kw. Why this slow? And why does the app still say the car is in my garage? Did it fry something else?
What should I be asking for? Hope there is someway to document good status.
Sounds like this could be like a friend of mines problem with his ICE BMW: his oil service left the filter poorly seated. After the oil leaked out, he had no oil warning but the car OVERHEATED and stoppeD. The service just put the filter straight and they put more oil in and since the engine turned over, he ended up with a kerfufel. HE WAS TOLD ALL THESE ENGINES CONSUME A LOT OF OIL and no damage done. He thought it changed a lot and just quit BMW.
