Peter_M
You used the wrong connector, find the other one farther up on the harness. The one you found is the Ambient lighting connector.
Also, you don't need to remove the bolts from the top to pop the bottom off a few inches. The door panel is flexible.
Thanks! I switched to the other connector and now it works properly. I had tried the other one the first time, but it had no power so I thought it was the wrong one. I guess it had just timed out.
And I found it was easier to remove the 3 bolts at the top to allow the panel to come away more at the bottom. You're right that you could do it without removing them, but it's a pretty tight space to work in.
