I want a proper grill guard for the Model Y
I know Tsportline has a brush guard, but it's 20 lbs, doesn't go up nearly high enough, doesn't cover quite the width it should, wouldn't do squat versus a deer, and has a bit of a janky method of attachment.
No, I want something heavier duty. Any ideas for companies that might supply one? Otherwise, I'm thinking I'll just go to a local metal fabricator/welder and have them put something together to my specs. Use the tow hook spot. Weld in another tow hook spot on the opposite side. Cut bigger holes in the bumper. Bolt in some square tubing or brackets coming out. And go on from there. That would keep the crash absorbtion and boost
Reactions: Hellpops
So something like this then?
