That's interesting data, but it's not complete. At least with some data, like from @David99, there are at least 2 types of pack readings, nominal full pack, and usable full pack, along with full remaining, and usable remaining. There are multiple SOC readings also, SOC, SOC Min, and SOC UI, and they are all slightly different, so you should designate which one you are referring to, or show the table. For example, your chart shows SOC = 6.5%, but your 4.3 / 70.8 = 6.1%. So they don't match in that case.Ran349, Actually it's two different things. If you look at the image you will see Pack 70.8 and Remain 4.3. On my S75 it's saying that I have a pack of 70.8 Kw and that 4.3 kWh is what's left in it. Here is the deal though my car says I have 0% and/or 1 mile or Rated Range left even though the pack really has 4.3 kWh left in it. As for the trip meter and battery loss think of it as a barrel of water with a hose attached. A gauge is attached to the hose side and is reading the water leaving the barrel but at the same time evaporation is happening in the barrel. As the barrel runs out of water the gauge does the reading very accurate but was unable to see the evaporation of barrel so the reading will be a little off each time.View attachment 369786
