spatterso911
P100DL - Raven
My question is... For the Fisker Karma drivers... What does the Karma do in very cold weather? Does it use battery power to warm the cabin, or does it get heat from the ICE?
It's and EVAH = Electric Vehicle Auxiliary Heat
Propane has about the same energy per kg as gasoline, so you'd need a pretty big propane tank to match even a 5 gallon gas tank which would provide something like 20 hours of cabin and battery heat at around 15F. Propane tanks are also big and heavy and difficult to fill on a highway.If the purpose is to produce heat, combustion is rather efficient way to do it. I expect that natural gas heating is more efficient than using natural gas to produce electricity at the power plant and then running it through a resistive heater.
If there were an auxiliary heater in an EV, I'd prefer it ran on something clean burning like propane rather than gasoline (how common is E85?). You could just periodically exchange the cylinder.
A liter would last a bit over an hour, but there's no issue with such short drives as there's plenty of battery power for both traction and heating. The problem comes when the drive is long enough that the battery limits are being approached.Chiming in from the Land Of Perpetual Cold (-27ºF/-33ºC on the first day of spring here, for example..... ), my suggestion is to, indeed, consider propane rather than gasoline. It is far less messy, AND I would ixnay anything like a 5-gallon gas or its equivalently-sized propane tank. Instead, make use of a campstove-sized, refillable propane tank. The reason? From my read of posts in this forum, almost all of you drive very small numbers of miles on each hop (for me, for example, it's a 200-mile one-way trip into town....and that's over the Alaska Range, too). A propane tank of even 1-liter would be more than enough to get you to/from almost any reasonable drive, and you also can throw a few extra small bottles into your frunk.
At $400/kWh, the price per kWh difference between the 60 and 85kWh packs, the extra 3.5kWh would add $1,400 and at the 150Wh/kg pack level density that's an extra 23kgs. Neither would seem like a deal breaker, especially since an alternative heating fuel system would not be free.Except that you might not need or want to pay for that extra capacity. Obviously if batteries are cheap and don't weigh anything, then the sky's the limit.
Sure, but that's only for 30 minutes of heat. If you want to do a 30 minute drive, just use the battery in the car, there's plenty for that short a drive.At $400/kWh, the price per kWh difference between the 60 and 85kWh packs, the extra 3.5kWh would add $1,400 and at the 150Wh/kg pack level density that's an extra 23kgs. Neither would seem like a deal breaker, especially since an alternative heating fuel system would not be free.
I thought the Model S already uses a heat pump system (which is why it has so many heat ex-changers).Maybe the better answer is for Tesla to switch to a heat pump system. They are supposed to be much more efficient, the Zoe uses one.
I would like such a heater, even for my Roadster. Need it for emergency use, if stuck in cold weather, but also sometimes to maximize range.
Did anyone install or plan to install such a system in a Model S? Roadster?
I know a 2 kWh diesel-fueled cabin air-blower has been installed in a Leaf, but I haven't heard of anyone that has installed a non-electric system that heats the battery.
How should a system that heats the battery be installed in a Model S/Roadster?
I guess since the temperature of the battery is liquid-controlled (unlike the Leaf) one could use the heater to heat the liquid. But what's the best way of doing that?
I guess warranty will be void, but the warranty of my Roadster is expired.
At my work we are installing Espar Airtronic diesel fueled cabin heaters for our Canadian customers. I am considering installing one of these in my model S.
My sense is that the big hit comes from heating the battery, not the cabin. The battery is a big, broad sheet under the car that is constantly radiating any internal heat to the atmosphere.
I'm writing this with a bit of remorse, as I do not advocate the direction of this thread. QUOTE]
yeah I know, seems like an anathema to electric vehicles to be putting some kind of fuel burner on it. But burning something to for heat is much more efficient than burning something to make it move. I still have to burn natural gas to heat my house unfortunately.
