Since a common type of thread here is "I bought a Model 3, so why am I getting much less range than the rated range?", here is a thread for prospective EV buyers to try to get a more realistic estimate of their actual range before they choose or buy an EV based on its rated range.
If your current or previous vehicle was an EV (or PHEV driven mainly within its EV range), you probably already know how your actual range compares to the rated range.
If your current or previous vehicle was an ICEV, consider your fuel economy in comparison to the rated fuel economy for your vehicle (see FuelEconomy.gov - The official U.S. government source for fuel economy information. for US EPA ratings if you are in the US). However, note the following:
Here are common reasons why economy and range are worse than rated for many drivers:
- Consider city and highway economy separately, since ICEVs normally do better on the highway, while EVs normally do better in the city.
- Be aware that, during cold weather, cabin heat is free in ICEVs, but is not free in EVs, where using cabin heat can be a significant economy and range penalty.
- Highway speeds significantly greater than 65mph.
- Hard acceleration and braking.
- Cold weather cabin heat use (EV only).
- Cold weather tire air pressures getting low and not checked.
- Higher rolling resistance replacement tires (including many higher performance tires and winter tires).
- Roof racks and cargo.
- Sentry mode or other reasons that the car does not "turn off" or "sleep" when parked (Tesla only).
