Am I missing something here? What’s the issue with getting a flat tyre? Why’s it such a concern? Can you not just get AA out with replacement tyre?
Actually does the model 3 come with a jack or any other item to assist with a flat tyre
The thing I don't understand is not shipping a spare when there is an under-boot space surely big enough for one (shape would need to change but doable).
Can we make this a sticky? The faux outrage and resolutions haven't changed a lot since 2019You think there's loads of space* ... you put a wheel/tyre in the boot and you see there's really not ... modern wheel sizes are huge. Even the "space saver" alternatives take up a surprising amount of space .. I know I've got one and I don't routinely carry it for that reason. It lives in the garage for call out purposes when within striking distance of home (which is where all the punctures I have ever had took place).
*they could give you room if you could manage without the rear motor
WARNING: NEVER TRANSPORT YOUR VEHICLE WITH THE TIRES IN A POSITION WHERE THEY CAN SPIN. DOING SO CAN LEAD TO SIGNIFICANT DAMAGE AND OVERHEATING. IN RARE CASES EXTREME OVERHEATING MAY CAUSE THE SURROUNDING COMPONENTS TO IGNITE. Do not transport Model 3 using any method that is not specified by Tesla. Adhere to the instructions provided in the following sections and observe all warnings and cautions provided. Damage caused by improper transporting of your vehicle is not covered by the warranty. NOTE: Tesla is not liable or responsible for reimbursing services not dispatched through Tesla Roadside Assistance. Approved Methods for Transporting NOTE: The tires are allowed to rotate slowly (under 3 mph or 5 km/h) and for a very short distance (less than 30 feet or 10 meters) only when Transport Mode is enabled (see Activate Transport Mode on page ) while the vehicle is being winched onto a flatbed truck or pulled out of a parking space for repositioning. Exceeding these boundaries can lead to significant damage and overheating that is not covered by the warranty. A flatbed truck or comparable transport vehicle is the recommended method of transporting Model 3. The vehicle can face either direction when using a flatbed. If Model 3 must be transported without a flatbed truck, then wheel lifts and dollies must be used to ensure that all four wheels are off of the ground. This method may only be used for a maximum of 35 miles (55 km), and must not exceed the manufacturer speed rating of the dollies. With this method, Tesla recommends the vehicle facing forward so that the front wheels are lifted and th..,
Spare tyre = weight = less efficient carThe thing I don't understand is not shipping a spare when there is an under-boot space surely big enough for one (shape would need to change but doable).
And for cost saving, a space saver steel wheel can't cost that much, surely?
Has anyone done a noise test with acoustic vs non-acoustic foam tyres? And maybe runflats too?
I had a flat tyre last Christmas, it took 7 days for anyone close enough for me to get to to have one in stock - I know that was due to the holiday closure but it was lucky we had an alternative car to run. I did try the Tesla callout number, I was on hold for 2 hours (yes, that is not a typo!) and then all they could offer was to get me to the nearest garage, that were, you guessed it, all closed by that time - I had managed to limp the car home by then so I declined. I have had a slow puncture since, that was much easier as it was repairable, and the garage said they could get a replacement next day if they could not repair so the first experience is clearly not typical and mostly just bad timing.
