AmpedRealtor
So much for WiFi connected MS's getting the first push of updates. Been connected for 48 hours and nothing.
A watched S never updates...
wow, 4 updates in a month. Seems like it's getting a bit excessive. Especially since I never got 5.6 but went straight from 4.5 to 5.8 (.22). I worry about quick turn updates - fully tested?
Perhaps this upgrade changes the charging system so that it again will be possible to charge with the full current/amps when the power is good. I have had the problem after upgrading to 5.6 that power is reduced automatically. I.e. when 32A is available the car only charges at 21/22A. Hopefully the update will allow full power on good installations..
That will never happen. The national electric code only allows for 80% of the max circuit draw for a continuous load. Our cars are considered a continuous load since they have the capability to draw max current for more than 3 hours.
Wrong. Was out for a Sunday drive with grandkids and, viola, the clock appeared.A watched S never updates...
EU is not US. Here the cables rated for 16A are rated for continous load and that's why people are pissed off about reduced charging. My EV bix is rated for 3x32A, but the car draws a max 3x13A, not 3x16A that the single charger should do.
By the way, I don't think this will prevent a problem with an undersized wire or frozen breaker. It could heat up and start a fire before the current fluctuations cause the car to cut back charging.
Sorry didn't notice it was EU. I agree that it should be location aware. Are you in 50hz? That should be enough to tell the car to adjust the charging rates if that's the frequency you have.
I had my 14-50 UMC charge automatically drop from 40A to 30A, on an outlet that I'm confident is robust (installed at a business location with many others).
Worried Tesla's new algorithm in 5.8.4 for dropping charger power might be overly cautious... :/ Wonder what it looks at for the input voltage changes? Droop only or oscillation? Perhaps their hysteresis isn't very good...
Are you confident that the UMC 14-50 Adapter is robust? There have been a number of reported incidents where the adapter to cable interface had failed and/or melted. Might be a good idea to pop the adapter off and check for signs of overheating.
That's a good point, I haven't checked the adapter specifically (I believe mine is one of the original versions). I will check it.
