Well there is a big source of our "disconnect". I assumed that they did pull 32A. Aren't they considered "Level 2" charging equipment?
32A is the MAXIMUM current for a Level 2 EVSE (Electric Vehicle Service Equipment) on a 40A circuit. The latest definition for Level 2 goes all the way up to 80A on a 100A circuit.
The small-paddle inductive chargers draw 27A maximum, measured with a good ammeter. The Ranger EV (I used to have one) draws even less.
"Continuous" loads are not to exceed 80% of the circuit rating, per the National Electric Code. The Code defines a continuous load as "A load where the maximum current is expected to continue for three hours or more." Electric vehicle charging loads are specifically defined as continuous loads.
The Code covers installations and installed equipment, not appliances that are temporarily connected to the installation by plugging into receptacles. UL covers the appliances.
Most conductive public charging stations are EVI ICS-200 models. Those have internal current-monitoring circuitryk that is self-resetting. Drawing more than 32A for more than a short time will cause the charging station to disconnect temporarily. It will try again after a few minutes, or it can be reset by removing the claw from the inlet and reinserting it. So, for those charging stations, it should not be possible to trip the breaker, which may be inaccessible. It's also not possible to draw more than 32A from the 40a circuit that feeds the ICS-200.
