With a transformer you can get the neutral (if the transformer has a delta-wye layout).
What I understand is, that norway 3-phase comes without N (4-pin connector) therfore you need L-L with 230V?
I am curious about support for 3-phase IT. From Bipo's pic, it looks like Tesla has a seperate UMC (mobile EVSE) for IT, and the label says it supports 400 V (phase-to-phase?) IT.
However, homes with 230 V (phase-to-phase?) IT can only charge with a single phase.
Alternatively, owners with 230 V IT can purchase a transformer to provide 400 V IT for their Model S.
Is this correct? Are these voltages measured phase-to-phase, or phase-to-neutral?
Thanks,
GSP
Correct. The transformer midpoint is connected to real ground via a spark gap. Each building is directly connected to ground via ground electrode. Only the phases (three wires) are connected to each building. So we don't have any N wire back to the transformer, only L1, L2, L3. A three phase cable for IT has L1, L2, L3 and PE.
My understanding is that three phase at 400 V TN, single phase 230 V TN and single phase 230 V IT are all supported, but not 230 V three phase IT.
It seems that the Euro UMC expects one of the pins to be neutral wrt ground and throws a fault when connected to a single phase IT outlet.
I'm not so sure this is the case - perhaps there is some EU regulation which requires it, but I would be willing to bet it's more of the case that the IT grid floats relative to ground without bonding. In the US, we have some cases where there is different potential of neutral relative to earth in more complex systems.
Finally, for what it's worth, in the US we list a three-phase system based on L-L voltage and add L-N voltage if it's a wye, e.g. 480Y/277V or 208Y/120V. Tesla lists the L-N voltage because that's the potential it's using in the chargers. I guess we can have philosophical arguments as to whether or not Tesla could multiply it by 1.73, but it would likely only be important to EE's. Most standard appliances you use are in the 230V range anyway, so equating it to common household appliances is likely the best move. Just my opinion, though.
No one has checked if there are two chargers under the back seat?
I quote myself... If someone here that has an European Model S can lift the cover of the back seats... Just to be sure
A Norwegian MS recently charged at 16 A from a 32 A Type 2 pole. So it looks like the twin chargers will deliver 22 kW, as expected.
I see... As expected :/ Thanks for the info.
Also good to know that the upper limit ia rated at 277 V... But for me it'd be nice to know the lower. Trying to charge at 220 V L-L 3 ph. (125 V N-L) would be interesting, as is exacty what I have at home.
For US chargers, I've been told it's 85 VAC. It obviously works at 120VAC in US homes. Not sure about the EU chargers though.
Then you need an EVSE that will work; it appears from Tesla's specs that the UMC will not work, but the chargers may.
It would be a 6 kW charging rate, which isn't too bad.
You have 220 L-L 3 phase? Wow, I've always heard Norway and Albania were the only countries to use that. Wonder how many more of us are out there. Do you have an N wire back to the transformer?
Well... I have it because this is an old house and here in Spain it was usual still 30 years ago. Anyway I use L-L voltage at home (so my sockets have no neutral), but I do have a neutral coming from the street (3 ph + neutral) so it isn't IT but TT.
Interesting. Then it must be the combination of IT and 230 V three phase that is unique to Norway and Albania. I didn't know anyone else used 230 V three phase.
Anyway, that you have an N wire to the house increases your chances of getting it to work, I think.
Confirmation that the twin chargers deliver 22 kW (click the "charger" plus-sign): Tesla Charging en_EU | Tesla Motors
Finally got my EVSE installed and operational today, plugged in and surprisingly I can charge with 3 phase 32 A, looks like that I also have the TwinCharger installed despite I got a document signed at delivery telling me that the TwinCharger will be retrofitted ...
No, it won't do 3-phase 43kW. If it would do so, why don't they say so in public?Another case... Lift the back seat cover, please please please
All the documentation says 22kW at max.
