Quick sanity check - I had the following quote for the installation of the Tesla charger that I've been given:-
Labour £230.00+vat.
Cable/Fixings/Cleats. £35.00+vat.
1x Matte protection unit £155.00+vat (If required)
I queried what the Matte unit was for and was told the following:-
"Regulations stipulate that all EV Pods require a separate earth from the building, this is usually done by installing an earth rod, we favour the Matte unit because it’s easier to install. We will check that your charge point doesn’t already have something like this fitted already.
Please see link to Matte website for more details.
Electric Vehicle Connection Units"
From a bit of Googling, I gather that the new regulations only require this if the charger is installed outside or the charging ever takes place outside. My charging will all take place inside the garage.
Also, I read the following in the Tesla charger's installation manual (p6):-
"The Wall Connector has a ground monitoring circuit that continuously checks for the presence of a safe ground connection and automatically recovers from faults. Manual testing and resetting is not required. Temporary problems such as ground faults or utility power surges are overcome automatically. If a residual current fault occurs that interrupts charging, the Wall Connector automatically tries to clear the fault and reattempt charging. If the problem is immediately sensed a second time, the Wall Connector waits 15 minutes before trying to charge. This process repeats 4 times and if all attempts are unsuccessful, power is removed and no further attempts are made. In this case, you will see a red error light on the front panel (refer to Troubleshooting on page 21). It is recommended that when you see a red error light, you power o the Wall Connector by switching o the upstream circuit breaker, and then power it back on again."
Am I right in thinking that I shouldn't need the Matte unit?
Thanks!
