wiztecy
Dialing back the Roadster Understeer may be an even more appropriate thread to merge the Camber talk into:
Dialing Back Roadster Understeer
My last alignment with the shims in, the camber came out to be:
Left Front: -0.5
Right Front: -0.7
(Left ABS mounting bracket shim thickness: 3mm)
(Right ABS mounting bracket shim thickness: 1mm)
*A 1mm shim plate affects camber by .25 degrees.
New front Camber (by math) after front ABS shims removed:
Left Front: -1.25
Right Front: -0.95
Now looking at this, I may add the left .25mm shim to the Left front. That way I'll have a -1.0 on the Left front and a -.95 on the right. Or the other possibility is on the next alignment to see if the right front camber can be increased to match the -1.25 Left.
Left Rear: -2.0
Right Rear: -2.2
Also appears Roger Reid did this same process sometime back. It appears that the only shims on the Tesla Roadster are the ABS brackets, so mine appear to have still been factory fresh with no extra shims:
SRRSCCA autocross results 8-14-10 [Archive] - Tesla Motors Club - Enthusiasts & Owners Forum
Left Front: -0.5
Right Front: -0.7
Left Front: -1.25
Right Front: -0.95
Left Rear: -2.0
Right Rear: -2.2
