That's not entirely true. My car actively cools itself while charging at 80A on my HPWC in the garage.
I wonder if maybe your car is cooling the AC/DC inverter, which could have its own heat rate from an outlet?
I really don't know. When I first plug in, it's quiet. Then as time goes on, after a couple of hours, I can hear a very faint fan noise. This gets louder as charging continues, but never as loud as it is at the Superchargers. This doesn't happen in the winter time, only in the spring and summer when ambient temps are above 90.
I have really not looked at Ideal Miles over the years, because it does not provide much practical value in day-to-day use. If I do a linear extrapolation, 241 Ideal Miles at 90% would equal 271 Ideal Miles at 100%. I'm not sure, but I thought the S85 was supposed to get 300 Ideal Miles when new.
Correct, Ideal doesn't provide much practical value. However, I've found that extrapolating Rated to Ideal never matches, sometimes it's close and sometimes it's somewhere overseas.
I've recently completed several long distance drives and cycled the battery from 100% down to zero once, and from 100% down to 4 miles once, and a third time from 100% down to 8 miles. I have not regained a single rated or ideal mile by exercising the full range of the battery as some have suggested. I have a B battery that just doesn't seem to care! lol
Must be user error then! LOL
What is the miage on your car and what's your 100% range?
Sounds pretty normal for that age/mileage. Mine is a tad older but a tad fewer miles, and my 100% also 255. I've seen a lot less variation in rated miles at various charge levels. I think theyve improved algorithm so calibration is not so impactful as it used to be.Mileage is about 27,400 miles and 100% charge w/ Range Mode off is 255 miles, with Range Mode on it is 257 miles. Ideal miles are 295 w/ Range Mode off, 297 miles with Range Mode on. Car was kept at 50% nominal charge for most of its first year before I switched to 90%.
At 90%, I have been at 362km (227mi) for the last few months, including on 101.*. Today with the 100% charge, Remote S shows the car is currently at 405km Rated (253mi) and 468 Ideal (293mi), 18 months old and 45,400km (28,375mi). New, from memory, was 425km (264mi) Rated on the car's display. I never did really look at the Ideal. So that's a little over 4% loss on Rated.
Nov 2014 picked up car with 185 at 90%. 5000 miles on the car. Now car shows 167 at 90% and 188 at 100%. Avg wh/m is 309. 21k on the odemeter. I charge to 90% each night. Getting concerned about the range drop.
That seems consistent with my experience. I normally charge to 80%, or 90% in the winter. At my car's 1 year anniversary in June, it had 169 miles at 90%, or 150 at 80%. Now it's getting 137 at 80%. Last winter, after charging at 90% for a while, it regained about 7 miles to 174. I've never charged to 100% and expect most of the gains will happen when I take a ~3600 mile road trip next year with lots of high and low SOCs to help calibration.Nov 2014 picked up car with 185 at 90%. 5000 miles on the car. Now car shows 167 at 90% and 188 at 100%. Avg wh/m is 309. 21k on the odemeter. I charge to 90% each night. Getting concerned about the range drop.
