InTheShadows
Wk057's solar panel circuits are optimized for charging a low voltage battery pack like he has installed and like the ones we install for our battery back up and off grid customers.
Standard grid tie systems usually operate at 300-450vdc. This is more in line with the tesla battery in the car.
Wk knows the float voltage of our car packs, I think they are in the 400v range but am only going from memory. So to have a standard grid tie solar panel pushing power into your battery pack in your car you need at least 110%, preferably 125% of the float voltage to get the juice to go into the batteries.
With those voltages you are bumping against NEC code for max residential PV voltage of 600.
IMO this may be an area that the powerwall is going to fill/address. It operates at 350vdc easily keeping within the bounds of NEC. if they are putting a step up DC-DC converter on it, that could easily regulate the voltage needed to charge our cars with out having to worry about the 600vdc limits.
Just my personal opinions though.
