Norbert
TSLA will win
True, but that will be AC -> DC, not AC 3p -> AC 1p
Weren't you talking about DC for the Model S?
That would be AC 3p -> DC, which was also my question.
One data center I worked in years ago had something like that.
By the way, do you know the function of these coils in the Aerovironment CHAdeMO chargers?
The discussion here is how you can go from AC 3ph to AC 1ph, which you won't be doing inside a car. That will be AC 3ph -> DC.Weren't you talking about DC for the Model S?
My question about flywheels is always how much energy they require to maintain their rotation.
By the way, do you know the function of these coils in the Aerovironment CHAdeMO chargers? :
I wonder if first rectifying the 3 phases into DC and then (electronically) making AC single phase would work. The result could be compact enough for a portable EVSE.
The wikipedia article features a picture of the Enphase M190. maximum DC input is 230W, AC output is 190W, weight is 4.4lbs. See DataSheet. The idea of 3phase -> 1 phase AC conversion is to get beyond the 16A single phase 3.6kW limit, and draw full 11kW. You need 58 micro-inverters weighing 255 lbs. That's more than 3 times the SunnyBoy 11000TL.
And we need the rectifier, too.
TECHNICAL SPECIFICATIONS
7.5, 10, 15 and 20kVA (three phase input and single phase output)
These are UPS devices, not just power converters. There's all kinds of extra stuff in there, e.g. batteries, that you wouldn't need.
Motor generators are one option that is used, but they are heavy, noisy and inefficient...
