First properly cold weather trip. I’ve driven in below freezing with my 3, but not this cold & also it’s a 2018 so no heatpump involved.
Temp is -16C (just above 0F), and I’m seeing the pre-conditioning come on nearly as soon as I depart from the last SC. Pulling up the Energy readout it says I’m blowing about 15% on pre-conditioning & another 15% on cabin.
That’s a lot.
Tried dropping from 20C/68F to 19C, couldn’t casually see a difference.
So took it one step further trying things out, I set my destination to the restaurant near the charger (dropping off passenger there anyway). Bingo, obviously no preconditioning cost but also Cabin then dropped to where I expected, negligible (two people generate a lot of heat, just need to dry it, which heatpump design does very efficiently).
Sooooo…besides somewhat slower charging & the nag that I should precondition next time, what’s the drawbacks here?
Note: I’m traveling into the teeth of winter, here. Headed to Saskatchewan & forecast has overnight down to -30C, maybe lower. I’m hoping to be off the road by the coldest but expect I’ll see -25C.
PS I’ve found some discussions here sort of dancing around this, a mention of the effect, but not quite coming out & saying this is a valid technique.
That’s a lot.
