Xenoilphobe
I'm near salt water, so I did a couple things, first I mounted these units about 5 feet off the ground so that the lawn debris / Lawn equipment / cars / etc do not hit my condenser coils. This also helps with cooling getting these away from the dense humid air that sits at ground level here on the coast. I mounted the condenser coils to the North face (again to help with cooling) of my house with brackets, into the studs (real 2x6), I was getting some resonate vibrations at certain loads, so I had to install anti-vibration isolation mounts, (Cylindrical Mounts V10Z64-MN10) which fixed the problem.What are you doing for maintenance? What's the cleaning routine?
I also have the gold coils, I cleaned them with a low pressure washer (ryobi 18 volt to garden hose) and some coil cleaner (end of summer) - TURN OFF POWER before spraying water on the condenser.
Monthly I pull the interior filters and clean them with hot water and soap, the worst one is usually in the kitchen because of all the cooking off gassing. Also drop a little vinegar or diluted bleach down the drip trays at the beginning of cooling season and make sure your condensate lines are clear (summer issue only). In the winter make sure your outdoor condenser coils are allowing condensate to drip out of the coil tray away from the coils, if they are blocked, it will create an ice dam and effect the efficiency of the unit, resolve by clearing the holes in the bottom and giving the water a path away from the coil (again why I mounted them higher and not ground mounted). Mitsubishi provides an optional base pan heater that helps with this as well. https://gotductless.com/cdn/shop/files/SUBMITTAL-3C30NA3.pdf?v=12788115341421047312
Also had to remove a smart bird, who had built a nest inside one of the line set cover box on the outdoor condenser (relocated to a bird house I bought), fixed that with a little chicken wire, so I don't have to mess with that again.
I don't know you config, but a lot of installers overload the outdoor condenser coil with too many heads, this reduces efficiency and could be impacting your low temp performance. (one of the reasons I went with single units verses multi heads to one condenser). Another issue I had with one unit in the first week was a leak, we found it and recharged, no issues yet...
I would check your interior filter first, then look at the back of your coil and see if there is debris (leaves, lawn grass, bugs, nests, etc...) A dirty coil has a huge impact on both heating and cooling. Keep everything away from the coil, there are minimum standoffs also, and a lot of people ignore those, which impact efficiency (see below).
Make sure your coil isn't in a wind path, you can block that path with bushes or even a low wall, but again follow the standoffs provided by Mitsubishi...Below ere are the LG stand offs, I mounted five units on one wall using the Case 5 standoffs below, following the standard factors. Mounting the unit 4 inches from the exterior wall (measurement D) of my house would have reduced efficiency 10%, so I gave these units plenty of room for air flow, and chose the standard 12 inches of "D" from the house as recommended in Case 5, below.
