sorka
Yes but shouldn't Tesla get alerts and call me proactively if my pack is having cooling issues? /Sarc
Wouldn't that be nice. My louver alert was logged 6 months before I complained about charging speed.
LOL! So if I call them up it sounds like they should be able to check for me remotely without me having to bring it to a service center?Wouldn't that be nice. My louver alert was logged 6 months before I complained about charging speed.
A year ago I took a road trip down to California and saw low charging speeds at a number of superchargers. I ran into a Tesla tech replacing cables at one supercharger and we got talking. He said they had been having lots of headaches with heavy use causing premature aging of the equipment at California superchargers. It only really started becoming a problem in 2016...
One more theory. I was watching the below new video from Bjorn discussing Range Mode. Apparently, one of the features of Range Mode is to heat up the battery while driving. With Range Mode off, the battery is being cooled.
Has anyone tested this PRIOR to arriving at a SpC? What if you arrive at a SpC with Range Mode having been on and a hot battery, versus arriving with it off and having a much cooler battery?
Forward to the 10:00 point for Range Mode and Temp discussion.
I never use range mode and experience the 60kW limiter often. Also, the outside temps do not seem to be a factor since this happens up and down the WA/OR/CA coastline when the ambient temp is in the 50's. I just went through it again. The ONE consistent factor is that the plug gets insanely hot if I leave it on a charger limited to 60kW for more than 10 minutes. It seems to be a bad connection.
This is my experience as well. With over 15,000 miles of Supercharging charging this year at stations from coast to coast and from Northern PA to the southern tip of FL, I can have a pretty good idea of my expected charge rate just by looking at how scuffed up the connectors are. Old worn connectors will pretty much guarantee a very rapid drop in charge rate. New connectors provide good sustained charge rates.
I had one particular empty charge stop that really made this obvious. The first spot had the normal rather worn handle and dropped from 116 kW to 60 kW within minutes. Moving a few spots resulted in starting again at 116+ kW to under 50 kW in even less time. I then checked the handles at the remaining spots and found 4 spots that had handles that looked brand new! Next move resulted in a charge rate that stayed above 100 kW for quit some time.
The problem is much worse in warm weather locations, with the ambient temperature high, the equipment can't cool down very fast between uses....
The tech said Tesla was actively working on long term solutions...
I have been in 20 states, every charger is different. I was in Orlando yesterday, got 150. Today in st augustine, got 40. I have been in full sites, alone, it makes a difference sometimes, not. I have a log of 7 months , 20 states, there is NO way to figure it out.
There must be... One hundred and fifty ways to lose your charger... hop on the bus, Gus.one 'fiddy' cent piece
