The system diagram shots are from an active diagnostic session and show different flows depending on the state.
Folks are confusing the passive radiator in the middle which coolant passes through during passive cooling and the condenser radiators that refrigerant passes through.
Those radiators are part of the HVAC system for cooling but that system serves the cabin AND/OR the coolant chiller. i.e in active cooling of other vehicle systems, the valves in the system can be turned or directed in many many combinations. The coolant can be isolated in multiple ways so that some systems can be passively cooled, actively heated, or actively cooled independently. For instance, the stator could be actively heated while the battery is actively cooled, or passively cooled. It all depends on what each system needs.
It's all actually very clever without being too complicated.
It is a cool system. (Pun intended). But in no mode can I see where the small twin radiators pass any coolant liquid to the battery pack.
Are you saying that maybe the battery line in the 1st photo is passively cooled as air flows by the twin radiators? It doesn't appear that any lines from the battery actually physically pass thru the small twin radiators.
This started at 110kw. Paired with nobody. Warm pack in Macon, GA
I was driving from Tallahassee, FL to Macon, GA in mild summer temps... It was plenty warm to supercharge- that's for sure. I've driven in near freezing weather for less miles and gotten decent temps right off the bat. Driving on the highway at speed especially the lower the voltage of the pack the warmer it gets.Do you know what your battery temperature was? Were your cooling louvers open?
This got me thinking a little- I wonder if Tesla is either looking at the distance to your home from the SpC you're at and throttling if you're within a certain range of home to deter the local charging folks that aren't using the network for long distance travel... or could they be looking at your destination in the nav and once the nav says you have enough to get there (especially if the address matches your home address or matches an address you've charged at) they drop the charging rate to something painful to ween you off the SpC tit.... I could have tested the 2nd theory by changing my destination, unhooking/rehooking up... but it didn't occur to me until after we left.
How can I check batt temp? If I have to get into the CANN bus or whatever I doubt I'm going to bother with that...You really should check your battery temperature. If it rises to 115F it will fall below the taper curve pretty quickly. It wasn't the fact that my louver was stuck closed but that being closed caused my battery temp to rise to above 115F which causes an almost immediate drop to 60KW.
yuk... so you used that tool to see your pack temp was 115+ and then checked the louvers and noticed that both weren't open during SpC sessions? Both of mine were open in Tifton on the way down... unless one or both are sticking I should be ok I would think.... Do the louvers open on every spc session?Yes, you'd need to get it from the CAN bus. I'm using TM-Spy which is available for both Android and iOS. Then I built a cable (there's a thread here somewhere on the parts you need) to adapt the CAN connector to the OBDII connector so you can plug in a cheap $20 Elm-327 scan tool.
Handle wasn't extremely hot in either charging session (Macon or Tifton)... I've felt them much hotter in the past.Can I also suggest taking the temperature of the charging cable handle using an infrared thermometer too? On a road trip in July I experienced the same symptoms (start high, drop to 60-80) at Tifton and Macon, maybe Lake City. In all cases the handle was extremely hot to the touch. I haven't taken a road trip since, but my plan for the next one was to take an infrared thermometer along, and gallon zip lock bags with ice.
Yes but shouldn't Tesla get alerts and call me proactively if my pack is having cooling issues? /SarcYes. But the louvers aren't the only things that can and do fail in the cooling system.
