Tesla charging options -
- HPWC - Hard-wired Wall charger with Tesla connector for car
- UMC - Mobile Connector with available adapters for many plugs. A 14-50 adapter and standard 120V 15A adapters used to be standard, but they are dropping some options. Make sure you have both. The connection to the wall plug is not designed to handle daily plugging and unplugging, that's why I have two, one stays at home, one in the car.
- Tesla Destination Charger - Public chargers, similar to HPWC that are located at many locations, such as hotels and offices.
- J-1772 - The most common EV plug solution. Tesla requires the J-1772 adapter to use. I'd recommend having one, again, Tesla may no longer be including these.
The cables listed above are all referred to as Level 2, which means that a full charge may take hours and are best used for overnight charging. Some J-1772 are free, some are paid. And while you can sometimes use a credit car when you pay, there are a number of different networks around the country and if you find the need to charge at them often, you may want to join that network.
Tesla Superchargers are available and primarily designed for long range travel. They provide the ability to cross the country. These are not free (unless you have free Supercharging) and are charged to the Credit Card on your Tesla account. While some think that they are extremely expensive (they are more expensive than home charging) they are relatively cheap when compared to DC Fast chargers that other EVs use. A Supercharger can charge to about 80% in under an hour, new V3 chargers can be even faster.
Due to an early promotion from Tesla to get people to but cars (free Supercharging for life), some Superchargers are located in metropolitan areas (especially SoCal and SanFran) and can be very busy.
So, in general, my recommendation
- Charge at home. This is an awesome user experience
- Charge at Superchargers when travelling. When combined with breaks, this doesn't necessarily extend trip time when compared to ICE
- Have UMC with NEMA 14-50 and 5-15 adapters in addition to J-1772 adapter when travelling. A number of hotels provide charging options, in addition, the 5-15 adapter can plug in anywhere
- Daily charging at Supercharging ONLY when you don't have L2 charging available at home or work.
Yes, it is a little confusing, and dependent on your travel needs, different options may be better. But if you go with the above option and maybe a heavy duty (very important) 25ft extension cord, then you can probably solve all of your charging needs.
For J-1772 plug (as well as Tesla) locations, use Plugshare web or app.
For better understanding of how far you can go, get in the car and say "Navigate to New York City" after a few minutes, you should receive the route, each Supercharger that you have to stop at and how long. Once you get rid of some range anxiety, you will realize that this is only a suggestion and that other option are available. Also, remember that this gets you to your destination, you may want to stay a little longer a your last stop to make sure that you have power to get around after arriving.
Tesla Superchargers and Destination chargers are available on the map by touching the lower right corner of the map and when the button appear, hit the charging button.
