yobigd20
I don't see anything that states an "order of magnitude" (i.e. a 10X improvement) longer life, given the same amount of total energy usage, which is what yogibd20 is implying above.
For the same amount of driven miles, if you only discharge to half your planned energy usage, an then recharge, you will double your number of charging cycles. Provided you don't hit the extremes of the battery limits, none o fthe curves I've seen suggest what you say.
Here's another example: Battery Life Article. The curve is not for Li-ion, but notice the text describing it:
"The above graph was constructed for a Lead acid battery, but with different scaling factors, it is typical for all cell chemistries including Lithium-ion. This is because battery life depends on the total energy throughput that the active chemicals can tolerate. Ignoring other ageing effects, the total energy throughput is fixed so that one cycle of 100% DOD is roughly equivalent to 2 cycles at 50% DOD and 10 cycles at 10% DOD and 100 cycles at 1% DOD"
This is the reason why I'm asking for a citation. Everything I've read agrees that shallower is better for Li-ion, but also suggests that discharge cycling at a fast rate is a reciprocal factor.
All other things being equal, shallower is better. What I'm arguing is that there's any real benefit (much less the 10x being claimed) for plugging in a bunch of times during the day as long as you don't hit extremes.
Li-ion is not Lead acid. Li-ion batteries actually count charge cycles based on a 100 percent discharge even when it's summed over multiple sessions. For example, if you discharge a battery to 50 percent one day, charge it back to 100 percent, then discharge it 50 percent again the next day, that is counted as one "cycle" of the battery. If you are at 80%, then discharge to 70%, charge it back to 80%, and repeat that 9 more times, that is 1 discharge cycle. And referencing that chart, this means if you keep your DoD to 10% then you can do this repeatedly for a total of 4700 full discharge cycles (aka 47000 10% depth-of-discharges). So the shallower the discharge the best for a Li-ion battery.
