Love my CarboTechs, they totally improve braking with the Roadster when dry. Now there's a new problem to attack. The crappy stopping power of the Roadster when wet. Its like going back to the old Brembo's you're hammering on the brakes when its raining out and the car's still skating forward. My guess is that the issue is with the rotors now. I think the drilled rotors with the rain is causing all the brake dust accumulated in the stupid useless drilled holes to slime up and now run out then being dispersed evenly across the braking surface. I'm feeling that moving to the custom slotted rotors (if it comes to a reality) will help alleviate the issue. Here's a thread on those rotors, reply in that thread if you're interested in a set:
Custom Aluminum Rotors - A possibility
And if that doesn't fix it 100%, I'd then add the big brake AP dual piston brake mod to the front. I'm sure the Roadster would then stop in the rain. Here's a pic of the relocation brackets for the front:
Here's the dual piston brake Calipers:
Right now I'm not happy nor confident in the abilities of the Roadster to stop when wet with stop or aftermarket brake pads.
Otherwise with AD08s on the back and AD07s on the front the Roadster sticks very well in the rain, does not want to hydroplane across water crossings running across the road and a very predictable car. However what scares me the most now is someone braking hard for no good reason in the rain who's in front of me and the Roadster skating with no ability to stop into the rear of the car. And of course in that case it would be the fault of the Roadster owner who rear ended the car in front of them in terms of damages.
If it stopped raining and the rotors had enough heat to burn off the moisture / slime then the stopping ability is back to normal with the Carbotechs.
The Lotus Elise forum also indicates this is an issue for them as well, even with a lighter car. They also mention that changing out the pads the issue still exist. And of course they have drilled rotors. Some in the forum were saying its the water film that's over the rotors, but its not. I've not seen any other car that I've driven where the braking has been reduced so much in the rain. I have to say at least least 65-75% braking capability is lost in the rain!
**Only thing is I think we need bigger / heavier braking on the rear in my own intuition for that I've seen warping of my rear rotors, not my fronts, which indicate they're working harder keeping up with the braking dynamics. Also since our cars are so low, weight favored in the rear and low, the traditional front suspension dive and weight transfer and weight transfer over the front wheels is not as significant as a traditional forward weight favoring ICE engine vehicle. My gut intuition here really is pushing me to beef up the rear braking. But until we get real data its all theory and one's own interpretation. **
