locksmack
I think he mentioned it because the manual includes a unique QR code to connect to the wifi.The Wall connector manuals are available online
Don't actually need the QR code to add Gen3 to Tesla app.I think he mentioned it because the manual includes a unique QR code to connect to the wifi.
Wrong QR code. If you try to use it, you get a message to use the QR code from inside the user manual.There is a QR code printed on the left side of the Gen 3 but my iPhone camera could not resolve the image because it was a low res print.
Makes sense. In any case it was unreadable because of the way it was printed.Wrong QR code
US and Canada only for now.anyone in Australia
Thanks.US and Canada only for now.
And you need a Powerwall as well.
(US/Canada noted in FAQ at bottom)Charge on Solar | Tesla Support
With Charge on Solar, your Tesla vehicle can charge using only excess solar energy produced by your solar system. Learn more about using the Tesla app to set Charge on Solar limits and more.www.tesla.com
My router is a smart router that dynamically switches between 2.4 & 5 GHZ dependant on the device.
I’ve been able to add my wall connector after the latest update. Just need the car now…USA, wall connector is not under add products yet
Can you show us in rhe USA rhe screen shots?I’ve been able to add my wall connector after the latest update. Just need the car now…
Also the version you have
Every WPA2 password is unique.Anyone know the default password of the Tesla wall connector?
YES! The missing critical pc. of info that Tesla omits! WC does NOT! broadcast nor listen on it's own little SSID _EXCEPT_!! at initial deployment or briefly after poweron. So an already-local-wifi-setup WC just sitting idle will NEVER work to connect to Tesla App if you just follow their instructions. Thanks.The SSID should broadcast itself for 10 minutes or so when after the charger is turned off and on again at the switch.
I think also the 5 second press of the button will also broadcast the SSID
I’m not sure I understand. They quite clearly state this. The first step in deployment is to energise the system by turning the breaker on.The missing critical pc. of info that Tesla omits! WC does NOT! broadcast nor listen on it's own little SSID _EXCEPT_!! at initial deployment or briefly after poweron
