So yesterday I had a lot of driving to do, so started out the morning with a 100% charge.
I finished the day back home at about 8% charge. I needed to do some work in the garage, so had to park the car on the street for about an hour, maybe 2, before plugging it in inside the garage. When I finally moved the car from the street, the battery was reading ZERO%. That seemed like a lot of drain, but I didn't think anything of it, especially since it didn't have an issue driving the 30 feet into the garage.
Plugged it in and that was that... except I forgot to change the charge level, so it went up to 100% again that night. Well, sort of.
This morning, I checked the charge level, and it was indeed set for 100%, but the SOC reported was only 97%, despite the car reporting "charging complete." I was curious why it said charging complete when it was at 97% and the charge level was set to 100%. The day before it charged to 100% no problem. I tried unplugging it and then plugging back in, but it just immediately stopped charging and went to "charge complete" status with it still at 97%. I had to do some driving so wasn't able to look into it any further. It's now down around 70%.
I'm curious though if anyone has an explanation for why it stopped charging at 97%? Does this have anything to do with the methods for "resetting" the SOC % that the BMS reports?
Thanks...
EDIT: the car is a S75, Oct 2017 build. 110k miles. Typical "full" 100% SOC is around 211, but I forgot to check what the estimated range was this morning (or yesterday). I do have ScanMyTesla if that might help.
Thanks...
