I really wish people would stop reposting this graphic as it is totally made up based on guessing
It is nothing more than informed speculation.
The 75.9 kWh number is not a guess. It is based on calculations. If you assume you don't know this number and try to calculate it from trip data, in most instances you will come up with a number that is pretty close. For example, in message #54 MarcG said, after a trip in his P85D he consumed 252-2=250 rated miles and 74.6 kWh energy. P85D rated range on Tesla website is 253 miles. Therefore the calculation is this:
If 250 rated miles equals to 74.6 kWh
Then 253 rated miles equals to X
X= 74.6*253/250= 75.5 kWh (X= Usable battery capacity in a new 85 kWh battery pack until rated range shows zero)
In this instance the result was -0.4 kWh off. I did many calculations and the results can be +-0.7 kWh off but generally speaking, 75.9 kWh is a good average. One reason the calculation doesn't always work is because the trip counter doesn't include consumption when the car is in park mode. When reading data from the trip meter, that trip has to be uninterrupted without parking somewhere between the beginning and end of the trip. If you parked somewhere for a while, you can't use that trip data for measurements. Another reason is, the consumption number the car reports is a calculation, not an exact measurement. It is not always too accurate. A third reason is, range mode on or off makes a difference. However, if you calculated the following for lots of different cars, the results would be close to 75.9 kWh.
Battery capacity when new = EPA rated range * Trip consumption in kWh / Trip consumption in rated range
