breakers are the only modern device I've found with Al ratings, I suspected it to be because you aren't allowed to splice in a breaker panel, and they want to be compatible with wiring in older houses. Everything else I've looked at recently has explicitly stated for copper wire only.
In the US, you are permitted to splice in a breaker panel.
The Leviton 14-50's - probably the most common one you'll find, is AL-CU rated:
P&S, Hubbell, etc., are as well.
