I think this will prove dangerous if you are rear-ended and don't have your foot on the brake--suddenly you will find yourself out in the middle of the intersection.But reports have it that BMW does it even better with the i3: apparently it will decelerate all the way to zero without using the left pedal.
Once again, no one said anything about shifting moving or changing the regen on the accel.The Model S does not have regen tied to the brake pedal in any way.
Source: 30,000+ miles of Model S driving between two P85s and a P85D while always paying attention to the power meter.
The power read out has *never* increased when the brake pedal was applied, even lightly.
Honestly, if Tesla shifts some % of regen to the brake pedal (pretty sure not possible with current hardware on any version) I will be pissed because that would cripple one of the best features of the car.
The issue is whether to have additional regen on the brake pedal.
Doing so would ruin the smooth braking that the Model S has.
There is only so much regen available so if you put some on the brake pedal you'll take it off the accelerator and complicate the braking system (Have you seen Toyota's diagrams of their braking system?). Doing so would ruin the smooth braking that the Model S has. It's a bad idea.
You can sure tell the difference in other cars that have regen on the brake pedal.No it wouldn't. It would be seamless. You wouldn't be able to tell the difference..
Only if/when regen and brakes are serialized i.e. only regen at first and then mechanical brakes later. No need to do it like that.You can sure tell the difference in other cars that have regen on the brake pedal.
...pressing the brake pedal would cause this magic/extra regen to happen along with friction braking.
Well, the issue with this is the the brake pedal physically controls the friction brakes. The iBooster setup doesn't magically make the pedal 100% electronic/programmable. So even if there were some way to magically find more regen (which I'm confident there is not as anyone with knowledge of how the inverter actually handles regen would also concur) then pressing the brake pedal would cause this magic/extra regen to happen along with friction braking.
Nope. The first fraction of an inch of brake pedal in almost all cars causes no mechanical braking. That's the exact part of the travel, that first fraction of an inch, that causes "more" regen in my other car. It requires a firmer press to get both. And the 'transition' (which may not even be the right word) is very smooth.
There is some hybrid that supposedly did what you say at one point with a complicated drive by wire braking system, but last I recall it was no longer done because the efficiency vs cost ratio of the blended (Prius/Volt) or one pedal setup (Model S) was much more logical.
I'll just go ahead again and state that there just isn't "more regen" available to add to the brake pedal even if the hardware were there (which it isnt)
Maybe the compromise could be that, if the driver has not opted for full regen on the go pedal, it would give it with a slight pressing of the brake?
I'm not sure imperceptible is the right word here. If you have a D, changing some of the load from friction braking to regen braking means you'd be moving it from front-of-car to front-and-back; for non-D, you'd be moving the braking work from front to back.I actually was surprised this wasn't the behavior of the "Low" regen setting, honestly, in an effort to gain additional efficiency for drivers who opt for this mode. Seems simple to blend some of the available regen with braking in this case. Would change the feel of braking a little bit, but would be mostly imperceptible essentially feeling like tighter brakes.
