They did, which is why it lowered before they introduced the smaller capacity battery. In WLTP terms it went from 352 to 340 miles.I don’t think Tesla advertised on the UK website using the range of the 82kWh battery
That is not what the warranty says though. The warranty says that a replacement battery will have the same or more capacity than the battery it replaced. So there is no "fleet average" or "normal curve" argument to make. The difficulty though is in knowing / agreeing what the capacity of the failed battery was in order to prove or disprove the new one is adequate.I don’t think Tesla advertised on the UK website using the range of the 82kWh battery - if you got one it was just a perk. Again happy to be wrong on that. If the battery isn’t faulty and it meets the normal degradation curve against the advertised range then they might just say no. I.e there is no longer a fault and no breech of contract.
Might be pedantic and I might be wrong but the BMS is in the penthouse of the battery. I don’t think Tesla take off the penthouse on the battery on a battery swap I.e. the BMS on the battery is the one that came with the replacement battery and the BMS wouldn’t be confused. I think it’s the car computer that takes the BMS voltage readings and calculates how far the car will travel for the current voltage / SoC.
Hey this looks pretty awesome. What app is this if you don't mind me asking? It's not the default tesla app right?It definitely wasn’t a new battery. From the readings I’ve taken it has done 45-50k miles. I’m on 23k. Either way the degradation was unworkable, I wouldn’t have got from home to work (or vice Versa) without a charge in the winter.
Just look at the drop in range / capacity in just a few weeks!
Wait, so if your battery is knackered and needs replacing the system automatically orders another knackered one to replace it unless the technician intervenes manually?Their system orders a battery of equivalent or better capacity if you are due a warranty replacement.
Tx
It’s an app called Tessie. Gets some really good data off the carHey this looks pretty awesome. What app is this if you don't mind me asking? It's not the default tesla app right?
Tx
Seemingly so. 3 times in my caseWait, so if your battery is knackered and needs replacing the system automatically orders another knackered one to replace it unless the technician intervenes manually?
