A garage is nice:
That explains cost. Numbered spaces I assume? Any worries on others using it?
Nice location for us . If your commute allows, you could only charge when there are multiple free spots, plus you will be there if it get busy. Can you get a charge point at work?
That adds to install (and monthly) cost.
For 13k, I'd use the supercharger, install one at work, or patronize businesses with chargers (or donate to Tesla to add an addition station)
Others could potentially use the space so I would probably have to put a lock on it if a better solution doesn’t exist.
I can charge at work if I arrive early enough
IF you are going to splurge on the 14-50, I'd go all the way and get the wiring installed which would support 48 amp or 72 amp charging...assuming it doesn't cost $$$$ more.
I think $13k is way too expensive for that though. Yikes! I'd just use public charging. Plus, won't you be able to walk to work?
After getting my 3, I don’t walk/bike anymore
The car is way too much fun.
And they won’t let me change anything (I.e 100 amps instead) since it’s all set by the design team
My thoughts are they are trying to rip you off. Ask for some detail on why it cost so much money. Where it is new construction it should be much easier to run the conduit and wire ahead of time and it should cost less than that.
Exactly - when I asked them to explain the other upgrades (i.e better carpet). The carpet I wanted costs an extra $0.10 per square foot compared to the standard included. So I figured they would only charge me the difference in material cost which is $100 but they wanted $8k!!
When I asked for an explanation - they said the material is cheap but the labor is expensive. And I responded exactly...you have to do the same labor whether you are installing the cheap or expensive carpet.
So I didn’t opt for any upgrades - they said all of the prices are from the design team.
