If it was wear from usage, one wouldn’t gain an extra 6-10kwh from a software change. Wear is not reversible.If by "bad" you mean "lithium plating caused by wear from usage" I agree with you. In which case it isn't warrantable.
What made the module go bad but didn't affect pack capacity? Most likely chemistry.Nothing is wrong with the chemistry, it’s a bad module. No need to go any further.
I'm saying that if you have an engine with reduced compression, without a hole in it, the compression has degraded. If your tires are bald the tread has degraded.A hole in the block has nothing to do with compression. The oil is on the ground and the motor is seized.
You can reverse plating with a software update? Please stop grasping at straws.If by "wear" you include lithium plating then I disagree. Some types of lithium plating can be reversed/stripped
Put some skin in the game, and take a capped pack apart. Knowledge isn’t free.What made the module go bad but didn't affect pack capacity? Most likely chemistry.
As for the definition of degradation:
Polymer Electrolyte Fuel Cell Degradation
Chapter 2 - Membrane Durability: Physical and Chemical Degradation
Chapter 3 - Electrochemical Degradation: Electrocatalyst and Support Durability
Chapter 4 - Gas Diffusion Media and their Degradation
Lithium ion battery electrolyte degradation of field-tested electric vehicle battery cells – A comprehensive analytical study
"the study of degradation mechanisms on cell level contributes to the understanding of aging phenomena and will enable improvements for future generations of LIBs."
Electrolyte degradation in anode supported microtubular yttria stabilized zirconia-based solid oxide steam electrolysis cells at high voltages of operation
"Degradation of solid oxide electrolysis cells (SOECs) is probably the biggest concern in the field of high temperature steam electrolysis (HTSE)"
At this point you're actively trying not to understand my points.Where in any of these links you have posted it says an imposed/artificial voltage capping is a valid response to battery normal/gradual degradation?
1) If not lithium plating (i.e., a type of battery wear from usage) what do you think Condition Z is?
2) Does any affected battery have > 30% range loss?
So you have no idea what's happening either, even though you have "skin" in the game.Put some skin in the game, and take a capped pack apart. Knowledge isn’t free.
I never said what is happening is normal. Never. What those links showed clearly is that the definition of the word "degradation" has a broader meaning in scientific literature than some of you are willing to acknowledge.I'm and you are not being helpful about it. Where in any of these links you have posted it says an imposed/artificial voltage capping is a valid response to battery normal/gradual degradation?
73. LITHIUM PLATING IS IMMENSELY HAZARDOUS - QnovoYou can reverse plating with a software update? Please stop grasping at straws.
Yeah, comparatively, I have my entire body in the game. I know exactly what the problem is. You would too, if you took my advice.So you have no idea what's happening either, even though you have "skin" in the game.
Why can't you explain it then? "Bad module" is not an explanation.I know exactly what the problem is.
