Not yet.
Since you have studied batteries forever, please explain how a capped car flashed version 8 software again, isn’t capped anymore. When something degrades, by definition it cannot go back to its previous state.What rosy outlook do you think I've expressed? Owning a vehicle does not necessarily provide any insight into the internal technology. Think about how many ICE owners know almost nothing about how their car works. I've spent a lot of time researching the workings of lithium ion batteries, including digging through research papers. I've also built my own battery packs and EV conversions. I've never tried to tell anyone how the Tesla App works or how to set driver profiles or anything similar because I have no knowledge of that. I do have some knowledge about lithium batteries.
From your link:Here is a US government agency explaining it to you: Battery Lifespan | Transportation Research | NREL in what looks like simple and easy to absorb language while still introducing you to the science.
Example of reduced-order life model capturing degradation in battery resistance and capacity performance with dependence on time, number of cycles, environment, and electrochemical state.
I've been over this. Obviously the capping is artificial. Equally obvious is the artificial capping is an attempt to counter some undesirable change in the cells, i.e. some form of degradation. Yes they could uncap the pack and range would return but the internal problems would remain. According to Tesla this would hasten capacity loss and potentially lead to fires. Neither of those is a good outcome, I assume we agree upon that?Since you have studied batteries forever, please explain how a capped car flashed version 8 software again, isn’t capped anymore. When something degrades, by definition it cannot go back to its previous state.
I never said it did. I said, repeatedly, that it may mitigate the negative effects of whatever is going on inside the cells. Whatever is going on inside the cells is not good, I call that "degradation", since something that is not working as intended is "degraded" from original. When battery resistance degrades, as referenced by that paper, it is a bad thing, but not necessarily related to battery capacity.Voltage capping does not cure degradation.
Please reread my post(a few times if need be). This has nothing to do with degradation.I've been over this. Obviously the capping is artificial. Equally obvious is the artificial capping is an attempt to counter some undesirable change in the cells, i.e. some form of degradation. Yes they could uncap the pack and range would return but the internal problems would remain. According to Tesla this would hasten capacity loss and potentially lead to fires. Neither of those is a good outcome, I assume we agree upon that?
That is what the word means. Compounds degrade, materials degrade, it's all degradation.If we accept that you use the word "degradation" to mean "fault, defect, or failure" your prior misuses make sense.
What does it have to do with then? Why do you think Telsa is capping the packs? You think they are doing it because the cells are just as good as new?Please reread my post(a few times if need be). This has nothing to do with degradation.
It does not matter if it is lithium plating or something else, that is pointless speculation.
The capping is still done to cover a design or manufacturing defect.
These new attempts on part of few here to coin the voltage capping as a cure for the battery degradation is not going to work, no matter how many times repeated.
You are trying to change the meaning of degradation. When you throw a rod in a motor, the block isn’t degraded, it’s broken.I never said it did. I said, repeatedly, that it may mitigate the negative effects of whatever is going on inside the cells. Whatever is going on inside the cells is not good, I call that "degradation", since something that is not working as intended is "degraded" from original. When battery resistance degrades, as referenced by that paper, it is a bad thing, but not necessarily related to battery capacity.
I've been trying to figure out what might be happening inside the cells, my current theory is as follows. Obviously feel free to ignore everything I write since it's just speculation.
Since the internal "defect" is somewhat mitigated by lower operating voltage I suspect it could be related to the electrolyte and electrolyte additives. Electrolyte is subject to degradation from excessive voltage. Similar to the way water breaks down above 1.2 V. If they had a bad batch of electrolyte, or a bad additive, it's possible they are seeing faster electrolyte breakdown than normal. This could mean undesirable side reactions which lead to clogging of the SEI layer and/or creation of volatile compounds. This may not affect capacity in the short term but might create dangerous conditions when charged to higher voltages and/or when charging or regening at higher rates.
If they reverse it and your pack starts losing actual capacity at a faster rate or catches fire is that "successfully reversed"? I would say no.unlike batterygate, which is successfully reversible.
If your compression drops it's degraded.You are trying to change the meaning of degradation. When you throw a rod in a motor, the block isn’t degraded, it’s broken.
Nothing is wrong with the chemistry, it’s a bad module. No need to go any further.
A hole in the block has nothing to do with compression. The oil is on the ground and the motor is seized.If your compression drops it's degraded.
