Maybe I'll wait for the SUV version, that will be climate controlled. I also saw the same thing happen to a Rivian on the spare tire box below the bed... so much condensation that water was sloshing around, must have had a clogged drain port or plug not removed or something. Rivian ended up modifying the gasket to resolve the issue.If the top is wet then the bottom will get wet when rolled open and then closed. No way around it as far as I can tell.
I also wish they had a climate control bed option.
My bakflip on my F150 never let any water in.Apparently many here have never owned a truck with a cover. I would say it did a good job.
seriously. of all the issues i have with the cybertruck... that cover "leaking" aint it.Apparently many here have never owned a truck with a cover. I would say it did a good job.
simpler is often better. I would prefer a fail safe soft tonneau cover you roll up / secure over this "vault" thing. but then... the Cybertruck has limited space in the frunk so you really need the bed secured... whereas with the F150 Lightning you could lock your valuables in the giant frunk and not cover the bed or just cover it with a soft roll up tonneau.I fully expect a s ton of problems with the retractable cover. I hope they poured sand through it like an AK-47 to test it.
Or something like My son has on his Tacoma. Strong, locking secure, water tight, simple,…simpler is often better. I would prefer a fail safe soft tonneau cover you roll up / secure over this "vault" thing. but then... the Cybertruck has limited space in the frunk so you really need the bed secured... whereas with the F150 Lightning you could lock your valuables in the giant frunk and not cover the bed or just cover it with a soft roll up tonneau.
Snow, ice and those tiny little leaves that clog the cabin filters, gutters and generally get tracked everywhere in the fall...where does it all go when the cover rolls up?I fully expect a s ton of problems with the retractable cover. I hope they poured sand through it like an AK-47 to test it.
DIAMONDBACK SE
DiamondBack SE is a locking hard tonneau cover made of aluminum that secures the bed of your truck against weather and theft. Shop now.diamondbackcovers.com
