I know it is recommended to charge to 80% for daily driving but I drive 85 miles round trip to work 5 days a week. Would it be better to charge to 100% since I don’t have a regular “commute” or stick to the 80% recommendation?
Ok, thanks for the information.Im not sure why you are asking about charging to 100% vs 80% for that commute. My commute to my work location is virtually the same (82-83 miles round trip). Whether you do it 1 day a week or 7 days a week really doesnt matter for this, because you should be charging every evening when you return home.
There is no benefit at all to "running it down to charge it back up", so if you are thinking you need to charge to 100% so you can try to charge every other day or something, dont do that, there isnt any reason at all to do that.
Just make sure you have some form of 240v charging at your home location, then, when you return home from your work commute, plug in and have the car set to 80%.
We’re in the Model Y forum and OP is from Texas. Every Model Y delivered to date in the US has the same battery chemistry and that battery chemistry is not LFP, which is the only one with different charging recommendations.What model (which determines what battery type)
Model Y PerformanceWhat model (which determines what battery type)
Model Y Performance
