Here’s an update to my initial saga. I was one of the ones (maybe only one) that SC would not install brakes because I have MPP rear camber arms. They said get them installed elsewhere and we are willing to finish config after it’s installed to reflect you have track package brakes installed.
I did get them installed by the same shop that did my MPP rear camber arms. Didn’t have any issues with installation and they also aligned the car. They told me after installing, the pedal felt a little soft but they bled them a couple of times and everything seemed fine after bleeding. I wasn’t too worried over that initially since I know some here mentioned that initial longer pedal travel. I drove it home from the shop but did not use the brakes because I wanted to bed them per ST website procedure that someone was helpful enough to post here.
The next day I put the car in track mode, turned down the regen as much as possible, drove the car out of city limits, and let her rip. I went through all the stops as outlined in the ST procedure. The 75 MPH medium stops got me in the red brake temperature zone along with corresponding warnings on the dash. I wasn’t too worried since the car did not know at that moment I had the CCBs and I’m sure was basing the warning on the much lower temperature limits for the stock brakes. I continued until completing the bedding procedure and then drove around to cool down the brakes below 100 C per the procedure.
All felt fine other than the softer than stock pedal but regardless, the car was really biting at full brake power. I made the SC appointment and they took the car in, gave me a loaner, updated the config and now the car shows it has CCBs and the app shows correct red brakes. After picking it up and after config change I noticed the pedal feel changed back to a lot firmer and immediate and for some reason the steering wheel feel changed a little bit.
So far I’m happy with the brakes and am happy with the SC being reasonable when it came to the aftermarket parts and at least giving me an option. As a bonus my cold start vibration that I’ve had since new, between 37-42 MPH during the first drive after sitting for a couple of hours, mysteriously went away with the brake install so the car is vibration-free now (miracles do happen!).
A few days before I took my Plaid for this SC config change appointment, my M3P was making that old school bus braking noise mostly when cold. A mobile tech came to see it and told me when they build up dust, especially on the cars with Brembos or bigger brakes, they make that noise. He looked at them on my driveway and burnished them and the noise did go away on my M3P.
Similarly, before the SC Plaid appointment, I noticed about a week after I bedded the CCBs it started making this same noise as my M3P, the loud braking noise which supposedly is dust according to the mobile tech’s explanation. I didn’t really want to tell SC when I took in the Plaid since they probably would wash their hands of it since they didn’t install them. Is anyone else running into this issue? I’m new to CCBs but is noise a thing with these?
