Do you have any suggestions on a good book/site to learn end-end? I've browsed a few things on youtube but some of the info seems dodgy.
Hmmm... oddly I can't recall any good single sources... I kinda learned the hard way as I went along...
Your best source will probably be the installation videos for each component... PV Quickmount has some great videos on how to find rafters , IronRidge has good videos on how modules rack to their rails and SMA has videos detailing the wiring of their inverters. There's also a lot of great blogs about separate topics like the benefits of oversizing.
If you have shading issues or a complex roof Enphase might be a good fit but it you've got a simple roof with a lot of sun a string inverter will save you a lot of $$$. Working with DC isn't too bad... the only rules to keep in mind are panels in series make a string and add voltage; strings in parallel add amperage. Use #10 wire for all strings and you'll be fine
