Hi forum,
My 2016 Model x 90D is having an issue with the drivers door. Latch won't open when the door handle is pushed from the outside nor easy grab on the inside. Does open when retracted all the way back, but then again opening motor is not moving the door.
Latch will close the door fully with the motor, but the window does not go up. Thus the car thinks that the driver's door is open, and yells every second while driving :-(
Somehow similar to other cases across the internet, but my simple question is: Does anyone know where the door open/closed sensor is?
I´m suspecting the sensor to be inside the latch (microswitch) and then it's an easy fix to replace the latch (got the very early revision with one cable and no actuator).
