P3dStealth
It's surprising to me that an outlet claiming to be rated for 50A isn't able to maintain 32A continuous. How did a product like that pass validation for being a 50A product? 32A is only 64% of max load - it should be able to maintain that without any issue at all.
My guess is it was a pisspoor installation with exceptionally loose wires, causing overheating behind the outlet.
I agree with you. Most of these melted 14-50 outlets are not torqued down correctly. I have been running a cheap 14-50 outlet for 4 years charging at 32amps no problems at all. I did however torque the lugs down to specs with a torque driver. It was surprising how hard the spec calls for and most people are not going to be getting there from just feel. My outlet doesn't even get warm.
The other issue with the cheaper 14-50 outlets is they are not designed to be unplugged often. If they become loose you need to toss them. I rarely unplug mine. If you do unplug it often get a better outlet.
I have no doubt the Bryant and Hubble are better. I think what's happening is the better product allows for an amount of negligence in the installation that the cheaper products do not. Also someone that seeks these high end brands tends to already know what they are doing and torque them correctly.
