Does your AGM manufacture OK equalization charging? That's a no-no for AGM's or gel's, as far as I know. Everything I've seen says you will permanently damage them (since you can't replace the water lost during an equalization charge.Would lifestyle come into play? I subscribe to the 90% charge every day at whatever comes out of the plug. I never know what my day holds, and therefore, like to have the full charge at all times. This is largely dictated by the fact there are currently no superchargers within my area (as of now). I suppose it's a matter of choice.
In the solar world (off-grid or grid-interactive), charging should be varied one every month or so to balance the cells. I use AGM batteries which have mixed thoughts about a normal float versus an occasional equalization charge. Would the occasional varying of charge voltages have a positive impact on a lithium-ion pack?
page 33 said:Equalization
Equalization is a controlled overcharge that is part of regular battery maintenance. Equalization brings the batteries to a much higher voltage than usual and maintains this high voltage for a period of time. This has the result of removing inert compounds from the battery plates, and reducing stratification in the electrolyte.
Equalization follows the same pattern as standard three-stage charging, as shown in the figures on page 28. However, instead of the Absorption voltage and time set points, it is controlled by the Equalize Voltage and Equalize Time settings in the MATE3.
The Radian inverter can perform Offset when equalizing. (See page 35.) Equalize Voltage is also the reference voltage for Offset during equalization.
This process must be started manually using the system display. The inverter cannot be programmed for automatic battery equalization. This is a safety measure.
Equalization is normally performed only on flooded lead-acid batteries. The schedule for equalization varies with battery use and type, but it is usually performed every few months. If performed correctly, this process can extend battery life by a considerable amount.
Equalization is not normally performed on nickel-technology batteries or any sort of sealed battery.
page 1 said:Absorbed Glass Matt (AGM) technology provides for efficient gas
recombination of up to 99% and freedom from electrolyte maintenance.
Off Topic: The previous post inspired me to compliment all our fellow forum members for whom English is a second language. The Tesla community is growing quickly in non-English speaking countries, and the participation in these forums and fluency in English are both fantastic. I admire anyone who can communicate well in multiple languages, mostly because my own attainment of that goal is limited (a bit of French and German, but certainly not fluent). So, my compliments to all those who already participate and a voice of encouragement to those who may otherwise be too shy - we are truly a global community now!
I have an HPWC with 80 Amp capacity. I set the current limit to 56 Amps. That cuts the resistive power in the wires, and each of the dual chargers, in half. 56 Amps is the geometric mean of 40 and 80 Amps and good compromise. Also, it uses both chargers, testing both each charge so that you know they both work.
