Great video by Ben aka Teslanomics on Youtube detailing his Refresh install!
Unplugged Performance
Unplugged Performance Refresh Front Fascia System for Tesla Model S
ugg.. I'm driving to LA in two weeks from Northern Cal.. might have to make a pit stop.. Since mine is black, is there paint matching needed or is black.. black..
For any of the standard colors (non multi coat red or multi coat white) we can pre paint then have you stop in for a quick turnaround
is titanium metallic considered "standard"?
... or dolphin grey?
This is going to sound like blasphemy but can someone recommend a front license plate bracket for this front bumper fascia? Will something like the LAW bracket fit okay? I’ve done the install and the oem bracket doesn’t fit correctly. I’ve been riding around without a front plate (which I love) but want to be ready in case o get a ticket I’m tje future. TIA.
Wow that’s enough to put me off this front bumper, especially at the price of it!View attachment 282511 View attachment 282509 View attachment 282510 Because of really poor fitment by my body shop here in Sydney Australia, and on the advice of Dave our local dealer, I took down the installation with a view to improving the fit. The end result is marginally better than it was, but I clearly have not got it right. It is obvious that not any panel shop can fit this product. They simply don’t have the time or inclination to play with the correct fitment of the fog lights which do have a significant role to play here. Also, my V strip was not symmetrical. That, I have fixed , by placing self tapping screws in the fixing tabs . Overall therefore a slight improvement.
I am looking for a good installation facility in the SF Bay Area ... who has experience with your refresh kit?Great video by Ben aka Teslanomics on Youtube detailing his Refresh install!
View attachment 296005 View attachment 296006 View attachment 296007 My installation has been modified by UP and my dealer here in Sydney, and it does look a whole lot better. Not perfect but acceptable and not really noticeable by casual inspection.
Essentially, two linked clips were installed on each side under the headlights, and held in place with 3M VHB automotive tape. The adhesive was allowed to “cure” overnight. (Same applies for any double sided tape, by the way - they all adhere better if left unstressed for a period of hours).
The bumper/fascia was prepared with two slots on the upper surface to receive the clips. Done with a Dremel saw. The clips and adhesive are under shear stress rather than pulling directly on the adhesive. This is much stronger than a direct pull would be.
So, once reinstallation occurred the clips engage the slots and forcibly hold the bumper much closer to the headlight, counter acting the forward “pout”.
I provide this information for others who may be experiencing the same issue. According to UP, the issue arose because heat was applied by the spray painter which caused distortion in the plastic which is not of the same composition as the OEM plastic and thus subject to thermal distortion.
Unfortunately, when I received it, the instructions particularly in relation to heat were NOT highlighted, and, the vast majority of commercial smash repairers just assume it is another plastic part and treat it as they would OEM.
I suggest that these parts have a large red adhesive label specifically stating that heat should not be used when curing the paint.
