somebodies accumulating................look at this am
and a closer look at 2pm yesterday to right now @12:39 it "curls up my toes"
In recent months, ascending triangles on the daily time frame that last two or more weeks have been good indicators for further upside (even if only for short-term gains). There isn't much space left in that triangle, so we should find out soon enough.Ascending triangle in the daily:
Ascending Triangle (Continuation) [ChartSchool]
Right. Carter recommends that the SP will make a definitive move roughly equal to the amount of time that it was being squeezed. So if you see it on the 60 min chart, you will be looking at a matter of hours. If you see it on the daily chart, a matter of days.Interesting. It's not currently the case on the daily chart, where the BBs remain outside.
Thanks, i don't see it in schwab, I will ask them ifI just pull up keltner channel, and bollinger band indicators in active trader pro / fidelity.
Carter sells his own proprietary software add-on for use.
He also recommends using a 12 period momentum oscillator in conjunction.
Thank you for explaining how to obtain this image.I just pull up keltner channel, and bollinger band indicators in active trader pro / fidelity.
Picture perfect. I wonder if we get a re-trace. I also wonder what the upside target is.Hmm, here let it be shown a TA indicator totally worked as it should have. I got some weekly calls for it but not nearly enough!
Yeah, resistance at the 50 day. I was looking at that too. We are just about at it now, so short term resistance should happen.Be interesting to see what happens when it hits 50 day sma
I might add if we get a bounce down off of it.Yeah, resistance at the 50 day. I was looking at that too. We are just about at it now, so short term resistance should happen.
Well, it did come back to the 50 day after briefly going over it. That was tradeable if you believed the pull back to the 50. One could trade (in theory) the zigzag around the 50 if that is the top for the day (which I suspect it is).Doesn't seem to care
Yeah, would be great if we close over, and it acts as support going forward.Well, it did come back to the 50 day after briefly going over it. That was tradeable if you believed the pull back to the 50. One could trade (in theory) the zigzag around the 50 if that is the top for the day (which I suspect it is).
