Here’s a situation that does not work with the current set up; try this: .... Try to edge your car slowly up to the end and stop… Ah, you can’t can you… see!
Why? Because you creep towards the end, feather the brake as you get close and the motor stops… let go of the brake and you jump forwards on the creep… clunk… bugger… quick check… phew, no harm done. I don’t want to do that each time and, I don’t want to press the go pedal AND the brake together to manage the movement… too much risk of excess torque resulting in a ‘Ferris Bueller’s day off’ ending.
I found this when pulling into parking spots. At first it was about 5 tiny "tries:" to eek forward. Now I can usually do it in 2 big ones. When I really feel comfortable with the exact size of the car I will be able to pull in once, brake and be done with it.
(It's hard to estimate the size of the car because there is not really solo-field safe way of knowing you have gone too far without damaging something. The car is low so parking bumpers and curbs will damage bodywork all around.)
