TeslaMate [megathread]
Thanks! That was the case, actually upgraded from 18>22 😲
Wasn't smooth though, was failing due to some issues with the lxd client so had to purge that first.
Now running latest Teslamate version and will try to remember to keep on top of these things in future! :)
I've just upgraded to TeslaMate v1.28.5 (from .2 I think!) and now the TeslaMate dock is constantly restarting. Just checked and I'm running docker 19 on Debian 9 (see below), so looks like I need to upgrade docker to v22? I've already done an apt-get update and apt-get upgrade, but it's not updated anything. Do you have the step-by-step instructions for what you did to force the upgrade?
myinstance@tm-f1-micro:~$ docker version
Client: Docker Engine - Community
Version: 19.03.15
API version: 1.40
Go version: go1.13.15
Git commit: 99e3ed8919
Built: Sat Jan 30 03:17:11 2021
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.15
API version: 1.40 (minimum version 1.12)
Git commit: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Built: Sat Jan 30 03:15:40 2021
Experimental: false
containerd:
Version: 1.4.3
GitCommit: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
runc:
Version: 1.0.0-rc92
docker-init:
Version: 0.18.0
GitCommit: fec3683
myinstance@tm-f1-micro:~$ hostnamectl
Static hostname: n/a
Transient hostname: tm-f1-micro
Icon name: computer-vm
Chassis: vm
Machine ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Boot ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Virtualization: kvm
Operating System: Debian GNU/Linux 9 (stretch)
Kernel: Linux 4.9.0-14-amd64
Architecture: x86-64
@Blokie These aren't exact instructions, just what I can recall. Before running this, ensure you know how to revert if necessary.
Alternatively, if you just want to revert to the previous working version of teslamate you can update the docker-compose.yml file, switching out the latest image for a specified version.
Code:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo do-release-upgrade
reboot
During the update process I encountered an error related to the lxd-client. Resolved this with:
Code:
sudo apt purge lxd lxd-client
Code:
sudo apt update
sudo apt upgrade
reboot
Code:
I don't think that will work. (It didn't for me, because Debian 9 has been deprecated and the sources have been archived. Security repo for Debian stretch not working anymore) I tried updating the sources and couldn't get anything to upgrade, so I gave up and just built a new Debian 12 VM and once I got it working I just backed up the data on the old one and restored to the new one.
Code:
sudo apt update
sudo apt upgrade
reboot
Code:
Thanks. I've reverted to 25.3 (25.4 had the same issue) and working fine, but I'd like to get the upgrade working. The issue is a bunch of errors when I even try to do the apt update...
Code:
myinstance@tm-f1-micro:~$ sudo apt update
Hit:1 http://packages.cloud.google.com/apt cloud-sdk-stretch InRelease
Hit:2 http://packages.cloud.google.com/apt google-compute-engine-stretch-stable InRelease
Hit:3 http://packages.cloud.google.com/apt google-cloud-packages-archive-keyring-stretch InRelease
Ign:4 http://deb.debian.org/debian stretch InRelease
Ign:5 http://security.debian.org stretch/updates InRelease
Ign:6 http://deb.debian.org/debian stretch-updates InRelease
Err:7 http://security.debian.org stretch/updates Release
  404  Not Found
Ign:8 http://deb.debian.org/debian stretch-backports InRelease
Err:9 http://deb.debian.org/debian stretch Release
  404  Not Found
Err:10 http://deb.debian.org/debian stretch-updates Release
  404  Not Found
Err:11 http://deb.debian.org/debian stretch-backports Release
  404  Not Found
Get:12 https://download.docker.com/linux/debian stretch InRelease [44.8 kB]
Reading package lists... Done
E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://deb.debian.org/debian stretch Release' does no longer have a Release file.
E: The repository 'http://deb.debian.org/debian stretch-updates Release' does no longer have a Release file.
E: The repository 'http://deb.debian.org/debian stretch-backports Release' does no longer have a Release file.
Just seen this reponse after posting my latest update - seems this is exactly the issue I'm now facing. Looks like I'm going to have to create a new Debian12 disk when I get the chance.
9-10 and that was enough to upgrade docker to get Teslamate working.
So how did you do the upgrade with the Debian 9 sources having been deprecated? This is what I get when I try the upgrade...
Code:
Ign:3 http://security.debian.org stretch/updates InRelease
Hit:5 http://packages.cloud.google.com/apt google-cloud-packages-archive-keyring-stretch InRelease
Err:6 http://security.debian.org stretch/updates Release
  404  Not Found
Ign:7 http://deb.debian.org/debian stretch-updates InRelease
  404  Not Found
  404  Not Found
  404  Not Found
myinstance@tm-f1-micro:~$ sudo apt upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following NEW packages will be installed:
  firmware-linux-free google-cloud-cli linux-image-4.9.0-19-amd64
The following packages will be upgraded:
  google-cloud-sdk linux-image-amd64
2 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 145 MB of archives.
After this operation, 65.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://packages.cloud.google.com/apt cloud-sdk-stretch/main amd64 google-cloud-sdk all 467.0.0-0 [1,706 B]
Get:2 http://packages.cloud.google.com/apt cloud-sdk-stretch/main amd64 google-cloud-cli amd64 471.0.0-0 [105 MB]
Get:3 http://deb.debian.org/debian stretch/main amd64 firmware-linux-free all 3.4 [19.2 kB]
Err:4 http://security.debian.org stretch/updates/main amd64 linux-image-4.9.0-19-amd64 amd64 4.9.320-2
  404  Not Found
Err:5 http://security.debian.org stretch/updates/main amd64 linux-image-amd64 amd64 4.9+80+deb9u17
  404  Not Found
Fetched 105 MB in 2s (46.5 MB/s)
E: Failed to fetch http://security.debian.org/pool/updates/main/l/linux/linux-image-4.9.0-19-amd64_4.9.320-2_amd64.deb  404  Not Found
E: Failed to fetch http://security.debian.org/pool/updates/main/l/linux-latest/linux-image-amd64_4.9+80+deb9u17_amd64.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
myinstance@tm-f1-micro:~$ sudo apt dist-upgrade
Need to get 39.5 MB/145 MB of archives.
Err:1 http://security.debian.org stretch/updates/main amd64 linux-image-4.9.0-19-amd64 amd64 4.9.320-2
  404  Not Found
Err:2 http://security.debian.org stretch/updates/main amd64 linux-image-amd64 amd64 4.9+80+deb9u17
  404  Not Found
Code:
  404  Not Found
  404  Not Found
  404  Not Found
  404  Not Found
TBH, I can't remember which version I upgraded from, was all a bit rushed.
Th
I googled "upgrade Debian from 9 to 10" and followed one of the many sets of instructions :)
IIRC this one:
Thanks - I've successfully upgraded to Debian 10 (buster) - clearly going from 9 to 12 (I'd used the same process and it failed badly!) was too much for it.
I've also updated TM to 28.5 too and that's working fine.
I suspect your mistake was not to change the references to stretch in the sources.list file, hence the mentions of stretch in your errors.
I thought I'd captured them all (sources.list and the various files in sources.list.d folder), but maybe not. When I get the time I might upgrade from 10 to 12 so I'm completely current (might even go 10 -> 11 -> 12).
I have created Teslamate dashboard for my personal use which focuses on speed and temperature related statistics. There are few options on the top of the dashboard to finetune the panels, selected date range also affects the panel data.
Screenshot below.
If you would to try or use it, you can download it from: GitHub - tero-jarvinen/teslamate-speed-temperature: Speed and temperature related dashboard for Teslamate
If you are using miles instead of kilometers, download the correct json file. One uses kilometers and the other one miles.
Very nice, just a couple of points.
I had to change my datasource manually in the JSON section of the dashboard - not sure if I missed something while importing - it's late here :)
The short and Long trip consumption panel still has km in the miles json.
But a very good addition to Teslamate.
I fixed the short and long trip unit problem. Also updated it to only include two trip lengths, three was probably too much for it.
But I could not find out what caused the datasource problem. If someone knows the reason I'll fix it.
Reactions: init6
