I have issues with mine that I will start a new thread on, but will follow yours.
I have issues with both mobile connector and Wall Connector at home. For the 14-50, I have an industrial Hubbell receptacle, proper gauge wiring (6 gauge copper to 14-50, which goes to 100 amp subpanel, 4 gauge copper off that run underground, to 2 gauge aluminum in the disconnect to my main 200 amp panel). No heat issues, no warm wiring, etc. Just stops charging all the time, often within 20 min to start with. I'm going to have my electrician check stuff out but everything is tight and proper, and inspected when all the work was done. No issues for 1.5 years now I can't charge consistently. At first I had to drop it from 32amps to 24ish, then 22, now it caps at 16amps itself. Once it said 'whoops why was I doing that?', and changed itself to 32amp on my mobile connector and charged all the way up no problem about 3 weeks ago.
