TSLA was a lot more exciting last year when it was going up every day.
Some stats show that it takes more electricity just to produce gas for an ICE car than an EV requires to run.
@JRP3
Sorry you disagree, but here is my source.
There is no exact
calculation for how much electricity it takes to drill, transport and refine a gallon of gasoline, but the accepted amount is around 8 kWh. So, for 8 kWh, you can go around 22 miles (
using the U.S. average; we know you can go over twice that if you drive a
Toyota Prius). That means that a gasoline car uses just under 40 kWh to go 100 miles. An EV, on the other hand, uses around 30 kWh to go 100 miles (given 3.3 miles per kWh, which is on the low side for some cars). Even if the exact numbers need to be shifted a bit one way or the other, we're just comparing electricity use here – not the petroleum that needs to be factored in for the ICE vehicle. So, if we were able to magically use all the electricity that is currently spent to give us gas and shove it into automotive battery packs instead, we'd use less energy
and no gasoline. So much for the long tailpipe argument.
Nissan sometimes
uses this argument when
advertising the
Leaf, but it's not a commonly used statistic. We wonder why.
How gas cars use more electricity to go 100 miles than EVs do
These rooting for tsla's bankruptcy are exactly the people who rooted for the freedom of the tobacco companies to kill people.
Very soon, you can brag before your brother because V8, afterall, is so 20th century artifact.
I gave 3 V8s a nice view of my P3D's taillights this past Friday at the drag strip.
A modified Dodge ram (was actually fast), a built up Chevy Bel Air (or similar), and a newer challenger/charger.
