Woah... any photos of that?Regarding storage, I determined that I can fit the J1772 cable under the front bonnet...
Other than price, the biggest downside is when traveling, my trunk will be filled with cables and adapters:
1 - UMC with NEMA 14-50 adapter
1 - J1772 Adapter
1 - Home-made NEMA 14-30 plug to NEMA 14-50 outlet
1 - Home-made NEMA 10-30 plug to NEMA 14-50 outlet
1 - "Spare" Mobile Connector (120V)
1 - 120v "cube" (to provide clearance for the spare mobile connector's right angle plug to fit into ChargePoint stations)'
It's quite a bundle, but looks like they'll all fit in the provided bag. Definitely bigger and heavier than the soft top.
So would it be better to just have a UMC j1772 adapter?
...you can't take advantage of the 70amp J1772-modified HPCs at the Rabobanks from Santa Maria to Salinas. ...
Do we have on-site confirmation that all the Rabo banks along the 101 have been converted to J1772 connectors? And more importantly, that they have been swapped out with 70 amp J conversion. I heard it is extra hard to get the high amperage J plugs
See here: J-1772 Converted Tesla ChargeStation LocationsDo we have on-site confirmation that all the Rabo banks along the 101 have been converted to J1772 connectors? And more importantly, that they have been swapped out with 70 amp J conversion. I heard it is extra hard to get the high amperage J plugs.
Looks like "on-site confirmation" is based on user comments in the four Rabobank locations and does confirm 70A for all four; the Salinas one does not report 70A *after* the switch, but there's no reason to believe it was downgraded (the others weren't).
Finally decided to head over to a Chargepoint location and see if it worked. I have the latest firmware (I think) at 3.6.1. It seemed to work fine although I only charged for 5 min, just long enough to see if it would work. It charged at 30A.
Oh, I may have typed that incorrectly. It's probably 4.6.1 (latest firmware as of mid June). My car is charging at the moment but I'll check when it's done. I do have a 2.5 Roadster.3.6.1? Isn't that for 1.5s? But you have VIN 1144. I'm VIN 690, and I have firmware 4.6.3, which Tesla confirmed is the latest.
My car still won't work at any Chargepoints whether I use the J1772 adapter, or my RFMC at 120V. I get a GFI fault in under a minute every time.
Tesla and Coulomb are looking in to it...
I charged today at Salinas, and it did charge at 70A, although only 201V.
The VehicleLogs will show both the full 70 A capacity (if that's what was available) and the actual charge current used. It's not terribly convenient to do on a moment's notice, but someone could download their logs and view them on a laptop to see if the full 70 A was available, but that would require waiting until the end of the charging session as well as the download time. My Mac log viewing application graphs both the charging capacity and actual charge current.If someone observed less than 70A, that may have been because the car was already charged to a sufficiently high level that it had ramped down the current.
Assuming that you can reproduce your problem on demand at a specific charging station, then ask Tesla Motors to send an engineer (not just a Ranger) to meet you there to diagnose the problem.Any other ideas on what I can do, or what they should do?
E.) I haven't even seen a J1772 charging station yet, so I don't really feel an urgent need.So who in the US is NOT buying one? And if not, is it because you don't like the design, the cost, or because you've converted your Roadster (or plan to convert your Roadster)?
The logic employed by thieves is questionable at best, and you probably should be careful trying to rationalize what they might and might not do based on your own perspective as a productive member of society. I've had my car stolen and they took $5 headlight bulbs that probably weren't worth the time it took them to cut the wiring harness and unscrew the bulbs. I've also had a $400 car stereo stolen, but the catch is that they only get $20 for a hot stereo. The remaining $380 is simply lost. It might seem silly to steal a $750 charger for $3 of copper, but if they can unload it for $5 to $20 then they'd surely take it. Maybe inflation has thieves being more picky, but I bet the economic downturn has probably reversed any effect that inflation may have had.Obviously no one is going to steal one of these adapters to use it or sell it to a Roadster owner. Someone might steal it as a prank, or maybe for the copper. There have been a number of thefts of charger cords in California, presumably for the copper. At less than $3 per pound, the value of the copper in Tesla's adapter can't be much.
Charring faults? or charging faults? Upon first reading this, I imagined your tech telling you that a little smoke or fire was nothing to worry about with the old PEM.I've got an earlier car (VIN 362), and heard from a service tech that my primitive and barely supported PEM should tolerate the adapter with only a few possible charing faults. He said to ignore them.
If you're willing to wait until your Roadster needs a firmware update for some other reason, then I assume that the Ranger fee might not apply.Well, I got an e-mail saying I'd have to pay the mobile Ranger fee ($920 in my case) to get the firmware update since it's a non-warranty repair. They're not willing to split the cost of the trip among all the owners in the area who need the firmware update either.
It's a very involved process - I've watched from a distance.I just had the firmware updated on my roadster. Looked like quite a bit of messing around with a laptop, adaptor cables and ODB ports.
