nativewolf
Some farms are installing solar and batteries for remote pumping. I think it is becoming cost effective against diesel or biodiesel.
Yep, there is a whole niche application in PV compatible water pumps.
...Through a combination of geothermal, wind and solar it will produce all the energy it needs," Musk said.
West-central Nevada is no place for geothermal energy of any scale. Not with today's technology.
I don't know if he means that kind of geothermal. It might just be that he means that they will place piping just below the surface, where the temperature is a constant 50-60F, and use it for cooling in the summer. Possibly also heating at night using heat pumps. This sort of ground heat/free cooling is pretty common in Norway.I have heard Mr Musk mention geothermal several times since proposing the gigafactory, and I cringe each time.
* IF the business park does possess an appropriate thermocline, then it would be well-documented by now and there is a fair chance it also would be being exploited, or in the process of being so. I have heard zilch regarding that.
* IF there are hydrothermal fluids in that area, I can come this close to guaranteeing that the fluids' Total Dissolved Solids not only would be not in the ppm or tenths percent range, but well into the percent numbers...and of such carbonates and sulfates so as to form transfer vessel-destroying precipitates within minutes of any dT's occurring...killing any such plant.
So why has he brought up that subject multiple times?
Your claim is countered by this article.
Geothermal energy has success in Nevada, wants to spread to the rest of the West | Ars Technica
AKA: CeramicIt's possible somebody has figured out how to clean the steam, or they are using some sort of advanced material that is more resistant to corroding for the turbine blades?
AKA: Ceramic
Ceramics Matrix Composites are non-corrosive, heat-resistant, lightweight, and harder than steel. Cost effective? Well, that's a whole different issue.
So you need clean, clean fluids....AND high-T fluids. And, truthfully, there's only one place to find that combination: in unicorn tears.
That was also confirmed in the video above.Could be ground source heat pump
