A lock that is integral to the plug and replaces the slider would be the cleanest solution for sure but it would require some intricate machining.
Can you post a picture of the slider by itself?
If someone is so determined that they're carrying the right screwdriver, they probably would also be willing to cut the cable or just vandalize the car. Best security system only slows someone down.
An advantage of the separate device is that it can be used with any Tesla charge cable, say at some public site. Or were you thinking that we can carry our screwdriver with us and change out the slider temporarily? :wink:A lock that is integral to the plug and replaces the slider would be the cleanest solution for sure but it would require some intricate machining. I will keep on tinkering with it...
The orientation is random. Good point, thank you for the feedback: I will make sure the next design is "right".With the plate it looks even better! Did you orientate the lock to the left for a reason? It just looks like the padlock should be on the right so that you don't have the chargeport door in the way.
...By the way, do right hand drive Roadsters have the charing port on the left or right?
