My daily commute is only about 4 miles though, so I am wondering if short trips are inherently bad to measure this on?
Yes short trips are bad. Because it take a ton of electricity to get the cabin up to temp where heater is running full load. Also slow speeds and heater really increase Wh/mi. I’m in the same boat.Ok, so I'm not the only one seeing this...got my M3 in mid November in uptate NY, and have noticed some heavy range loss (as much as 50% or more) when it drops below 30 or 20 degrees F. I have started tracking it every day in a spreadsheet, because it alarmed us and my wife was concerned there was a problem with the car.
Even with charging up for a hour before I leave, in Chill Mode, and driving like an old lady, still getting poor efficiency. My daily commute is only about 4 miles though, so I am wondering if short trips are inherently bad to measure this on?
If you can just plug the car into a regular outlet overnight, that will help keep it warm. Not always an option...but usually is, a lot of parking lots and parking garages have a few random outdoor outlets. Another option, at least in the S, is to run the heat for an hour or so before you leave. Doing so helps to heat the battery, initiate from the app.
Wonder if a hill hold (if there is a hill) can heat up the pack quicker without damaging the motor. For the shared heating/cooling system, not sure how the algorithm prioritizes.
Also I’ve figured out that if it’s plugged in and done charging when you pre heat it draws the energy from the battery not the line. So the sudden mile drop is probably correction for that battery loss used in pre heating. Also the battery mile meter is useless in the winter. Try switching to % and use the energy app to gauge range and Wh/mi? Also when you leave do you go up hill. Up hill is the largest energy drain. I go downhill to work and uphill back. It’s about 8 miles each way. There are times I use 1-2% (3-6 miles) there and 7-8% (21-24 miles) back.I'm not talking about heater loss, I don't think. My car is in the garage at night, and I tell it to warm up to 70 while it is charging before I leave. When I unplug the car in the morning to leave for work, the inside is already toasty and my energy consumption (since last charge / since right now) is reading zero.
As soon as I drive out of the garage though, I start spending energy quite quickly, at about a rate of 2 miles of range for every mile traveled. So, in my five Mile drive to work, expending about 10 miles of power. I don't think that is cabin heater since the car is already warmed up.
I suppose I could test it though, and drive to work with the heater off, see what results I get? Is only 5 degrees out right now, should be fun haha!
How are you figuring it doesn't draw from the line? Anytime i've turned the heat on you an see it kick off drawing power from the outlet if the car is plugged in.
I believe what it does is the Heater is on the "DC" side of things. When Plugged in and Cabin Heat is on, power goes through the Inverter and straight to the Heater. Bypassing the Battery.
It's kind of like a PowerWall Setup. Where Wall Power in your car is like Solar Power in a Power Wall. When Solar is Producing and you present a load, Solar Power goes straight to the load. If no load, it can charge the battery. If no Solar Power the Load gets its power from the battery.
It's probably very similar switching/sensing tech. Except what's AC and DC in the two systems.
this is still pulling power from the wall and coleAK is saying it doesn't from how I read his statement. IF your car is plugged in and you even just open the door and it kicks on climate it will start pulling from the wall, as it should.
It’s all good. Early on this winter I did some testing of my own. And was surprised as well. Makes sense though as electric heaters all draw a lot of power. I think the glass roof also dosnt help with containing heat. I’m thinking of trying to make quilted insulation panels like the Tesla sun shades.UPDATE. coleAK I owe you an apology
So I did my test this morning. Charged the car up for 30 minutes before I left for work, but shut off the climate control. I then left and drove to work with the climate shut off and no music, which was fun at zero degrees F this morning. Holy hell if that wasn't the most efficient run I have ever recorded, came in actually at 100.7% because I technically drove more miles than I used in battery range. My Wh/mi was only 212. I don't remember ever seeiing it below 350. I was stunned. I had no idea the heating system took so much power.
Sorry I doubted you.
Wish I could do that every morning but the problem is the windows all fog up and I can barely see a damn thing haha.
To answer your other question, no real hills between my house and work. It is pretty level, except for a rise over a railroad bridge.
It does not keep it warm just because it’s plugged in.
Ok, you have to have it charging, but I assumed that was understood.
