Good luck today. Hope they have it fixed for you.
Well you sure can't fault the customer service... They build the drive units in house no? Hopefully they figure out what makes these noisy one's different from the others and can stop it at the source.Like others who have posted, my drive unit was replaced.
I have recently started observing the same low frequency sound at speeds 75mph and higher. It is interesting that my first thought was that the noise consistent with wheel bearing going bad, similar to other posters. I kind of dismissed this initially as a rear tires related issue (Mishelins PS2, about 7,000 miles, will probably need replacement at about 11,000), but yesterday during the day trip with all family members in the car, both my wife and son commented on the noise, and my son sitting in the back also noted noticeable floor vibration at the same speeds.
Try this: While driving at speed and observing the drone sound, back off on the accelerator until the power meter reaches zero and see if the drone sound goes away. This was my car's behavior and I could make the drone sound come and go at will by doing this. If not, it may very well be a tire or bearing noise.
Just got mine back from the body shop after being rear ended. Did not get a new motor. The boominess starting at 63mph has been curtailed. The volume still goes up around there, but the very obvious booming drone noise has abated. Course the ambient temperature is also very different now. But perhaps it's not the motor itself that is causing/amplifying the noise. It'll be interesting to see if the noise returns after a couple more months.
Thanks, will try. At this point I am pretty sure it is not a tire noise, as I observed the exact same noise at the same speed in the rain. If it would be tire related, as a minimum, noise would be different in the wet weather and could almost disappear. The suspect #1 IMO, is motor bearings. The noise does not sound as frequency induced electrical hum, which is associated with vibration of motor laminations against each other at certain frequencies.
Would be interesting to hear any competing explanations. Ultimately I will make sure to question the service center guys as to possible root cause when I take car for service.
The SC fixed my hum after two inverter swaps. I can drive really fast 85 mph+ without any drivetrain noise at all.
That's why I upgraded to the studio sound package.:smile:Nothing to drown out those police sirens :biggrin:
