chickensevil
Has Elon or anyone mentioned why they aren't using parachutes to help slow down the first stage during recovery?
I don't think so by them but it has been discussed by others and it really wouldn't work. Issue one, added weight. The chutes take up both space and weight on the rocket meaning a lower payload. Issue 2: the speed that the craft is moving EVEN AFTER its initial burn coming back into the thick part of the atmosphere would shred through the chutes and male them useless.
I know what you are think the capsules have all used chutes why not for this? The difference here is that the capsules have a rather large area under them that have been heat shielded and then they push the craft through a very shallow angle into the atmosphere causing it to have a lot more time and resistance to slow down. Instead these rockets are not shielded (the the extent that would allow this) and are taking a very steep angle straight down. This causes them to break through the atmosphere with minimal slowing.
Finally you are overestimating how costly the fuel is to the rocket payload. Consider that from launch to separation you have a full 2 minutes 30 seconds of full 9 engine burn. How long on the return are they relighting the first stage? 15-20 seconds? And we are talking just one single engine. So that is assuming 30 seconds 1/9th of 1/8th the fuel needed to slow the first stage. It is really not that much.
It is a common line of thinking but it just doesn't work in this case.
